RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
A
Anonymous Posted on Dec 29, 2012
How do i fix my blackberry with the app error 552 reset?
Where is the reset botten
5 Related Answers
Anonymous
  • 541 Answers
  • Posted on Aug 13, 2009
SOURCE: I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
Anonymous
  • 3 Answers
  • Posted on Oct 04, 2009
SOURCE: how do i solve the APP Error 523 on blackberry
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Anonymous
  • 1469 Answers
  • Posted on Jun 22, 2010
SOURCE: I have a blackberry storm. When I woke up this
HI,
I suggest the following steps (insert plenty of reboots of your PC...not just restarts, but full power down reboots). Also, it is advised that you be logged into the PC on an account with full admin rights. Further, under Vista, use the "Run As Administrator" option for everything. If you have never installed the Desktop Software to your PC, then skip steps 1 and 2.
1) Remove your device OS update package from your PC (add/remove programs)
2) Cleanly uninstall the RIM DTM software:
  • KB02206 How to perform a clean uninstall of BlackBerry Desktop Software
3) Get a fresh download of the RIM DTM software:
  • Choose the version that is newest and (if applicable) compatible with your PIM (if you are synchornizing via USB):
  • KB12268 Applications supported by BlackBerry Desktop Manager for synchronization
4) Download (to your PC) a fresh copy of your device OS package from your carrier:
5) Install DTM to your PC
6) Install (also to your PC), the device OS package
OK...next, follow this KB (including the other links within the KB) for recovery from the 523 error:
  • KB11816 Error "523 app.error.Reset" appears on the BlackBerry smartphone
Good luck and let us know!
Anonymous
  • 17 Answers
  • Posted on Jul 05, 2010
SOURCE: how to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
Anonymous
  • Posted on Aug 06, 2010
SOURCE: how to correct app error 532 for blackberry curve
i have the same problem, what did you do to fix it?
1helpful
What do i need to do if my blackberry curve displays a message saying reload software:552?
I have had the "Reload Software: 552" error on 2 BlackBerry Curve 8900s. When it occurred again (last night) this is what I did:
[ WARNING! THIS WORKED FOR ME, BUT I WAS LUCKY & IT MIGHT NOT WORK FOR YOU! ]
1. Reboot your BB: alt-rightShift-del
2. Start a software reload from the Windows desktop, via the BB Desktop Manager.
When the reload started, I would get a screen on my BB showing 2 computers talking to each other. After a few seconds, this would crash into the 552 error.
3. 3-5 seconds into the software reload, CANCEL the desktop.
4. This should freeze the apps on both the desktop and the BB. The BB should still be showing the 2-computers.
If you do anything on the desktop at this point, the BB will crash into the 552 error again.
5. Terminate the desktop app processes via the Windows task manager. There are 4 RIM/BB processes to shut down.
6. At this point, the BB Desktop Manager app should be gone, and the BB should still show the 2-computers.
7. Now, start the BB desktop manager back up again, and intitiate the software reload again ...
A 4thumbs up will be greatly appreciated. Thank you for choosing FixYa!
On the screen it says reload software 552. How to fix it?
Download The Desktop Client and restore your device. First make a back up. (software will have option to do so.)
http://us.blackberry.com/apps-software/desktop/
1helpful
552 error
Reload software: 552 or App Error 552, known issue in Blackberry. To resolve, upgrade to the latest available BlackBerry Device Software version provided by your wireless service provider to resolve this issue.
Complete the following steps:
  1. Verify that the BlackBerry® Desktop Manager and the current BlackBerry Device Software (for your BlackBerry smartphone) is installed on the computer.
  2. Remove the battery from the BlackBerry smartphone. Do not re-insert the battery.
  3. Open the BlackBerry Desktop Manager on the computer.
  4. Connect the BlackBerry smartphone to the computer using a USB cable.
  5. On the BlackBerry Desktop Manager main screen, click Application Loader.
  6. In the Update Software area of the Application Loader, click Start.
  7. Click Options. This allows you to add or remove applications from the BlackBerry smartphone.
  8. Select the applications that you want to install.
  9. Click Next.
  10. Click Next.
  11. Click Finish.
  12. When the application load process starts, insert the battery into the BlackBerry smartphone.
    Hope this helps!
6helpful
2answers
My phone is saying reload software 552
on my blackberry curve 8520 has reload software 552 on front of the bb screen when i turn on my blackberry / it also will not power off ..can u please help me .. how can i fix my phone
Sep 21, 2010 • Cell Phones
2helpful
I keep getting an app error 523, i removed all of
try a factory reset:
How to reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Black berry error code 552. White screen with
you need to connect the phone to the computer or laptop that you are using via usb cable and open teh blackberry desktop manager and go to application loader and install the OS you want and it will be up and working great again.
7helpful
3answers
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
1helpful
Blackberry 8310 app error 523
how can i fix error 523 on a blackberry 8830
My BB has an error code: app error 552. what do i do?
If you're having this problem a lot, make sure that you've moved all of your media (ringtones, music, video, pics) to the Media Card. Clear the Cache on your browsers, adjust the memory reserved for pics. That should clean up many of the issues
Try changing the default location for pictures taken. I've set mine to default to the memory card saving a lot of space on the phone to allow for other more important things.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
