FRUSTRATED. NEED HELP . WHY DOESN' T THE AV MODE I SELECT WHICH IS STANDARD STAY IN STANDARD. AFTER A FEW MINUTES THE AV MODE RETURNS TO DYNAMIC FIXED.
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu
when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
THANKS DONALD! THIS WAS DRIVING ME NUTS!!!!!!!!!!!
13 years later and this is still a problem. Sharp could not fix my tv which was resetting to Dynamic(fixed) every 20 minutes exactly. This article got me to check. I found the location was set to Store. I changed it to home and the problem was solved. Thank you for posting about this.
Thank you so much!! I've been going crazy trying to play my Xbox. Every time I was doing good, the tv would dim and I'd die lol. Thank you soo very much(:
It resets after every 30 minutes. You can set your clock to it. I don't know how to fix it. It's quite annoying for the color to abruptly change three times in the middle of a movie...
