Re: forgot lock pattern on lock screen on a 7" uniden...
I have a uniden tablet and have had it for about 6 years now I forgot the password and I can't get into it. I have tried everything can someone help? ??????????
how to reset links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Turn your tablet off and remove the SD card, if there is one.
Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Hi Mercedes, you will have to perform a factory reset to take the tablet back to when new!
Power the Tablet down completely. Press and hold the Power and Volume up buttons until a recovery screen appears. You should be presented with a screen that will allow you to perform a Wipe Data Factory Reset. Perform the reset then restart the Tablet.
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here... http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
