Install cwm through odin. Open cwm while startup by button combination. Select another superuser 3.1.3 file. Select instll click ok. Your phone is rooted.
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
To unlock your SAMSUNG GALAXY S SGH T989 model phone use unlock code.Visit the site www.mobile-unlocker.com get unlock code at reasonable cost and unlock it from service provider lock easily.To get code you also need to specify the current network and country it is locked now.If it is available get code and unlock it.
Hi, To which network has your Samsung SGH T989 Galaxy Sii been locked to? You can unlock your Samsung SGH T989 Galaxy Sii safer and easier using unlock code. You can get the accurate unlock code for a Samsung SGH T989 Galaxy Sii from www.mobileunlocksolutions.Com at affordable cost with free unlocking instructions. Good luck mate.
There are a lot of root tools like iroot ,kinggo root and SRSRoot to support root.What i suggest most is Iroot.
http://www.iroot.com/iroot-for-pc
just make backup of your Samsung data And enable USB debugging mode on Samsung device Before download. Then,follow these steps:
Step 1. Choose the right version of iRoot(android version or PC version) to be downloaded for you. Here we take the PC version to illustrate how. Step 2. Connect your Samsung to your computer with a USB cable via USB cable. Then click "Connect". And then, install driver. Note: Choose "User Agreement" means you accept our service. Step 3: After iRoot detects your Samsung Galaxy 2, you can move to root your device now. Just click "Root" to allow this step. Step 4: By this step, once your Galaxy S2has been rooted successfully, it will reboot automatically. Step 5: After iRoot detects your Samsung Galaxy S2, you can move to root your device now. Just click "Root" to allow this step. Hope enjoy.
