When using the Makita saw JR3000V there is a loud tapping noise
SOURCE: wiring varible speed swith for a Makita JR3000V reciporcating saw
The replacement switch, is it Makita and was it a direct replacement for the original part? That could make a difference. I looked at the schematics for this tool and they do not furnish the wiring codes but I think you are on the right track. To make sure though I would call Makitas tech support people at 1-800-4625482 and have a wiring explosion sent to you. Let me know if you still need more help and I will contact them or call a local dealer that I know.
I removed the gear housing cover and found that the side wall was slightly warped where the N. bearing rotates back and forth. After some vice work and straightening the wall and reinstalling the parts everything seems to work fine Thanks for your comments which are always helpful.
