Bunn NHB Coffee Maker Logo
Monya Sparks Posted on Dec 29, 2012
Water coming thru coffee maker very slow
Have cleaned the coffee maker according to the manual but the water comes thru VERY SLOW - it's taking up to approx 10 - 15 minutes to brew a pot of coffee Any suggestions you can give me would be greatly appreciated
rapier78
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 15 Answers
  • Posted on Mar 24, 2014
rapier78
Contributor
Level 1:
Night Owl:
Answers
15
Questions
0
Helped
18650
Points
21
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
4 Related Answers
A
Anonymous
  • Posted on Sep 19, 2007
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Danobegood
  • 5 Answers
  • Posted on May 23, 2008
SOURCE: Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Anonymous
  • 189 Answers
  • Posted on Jun 02, 2010
SOURCE: cleaning
The metal proble is use to clean out the water tubing. Remove your sprayhead and insert the metal rod up in the hole leaving out about 1-2 inches. Then simply twist and turn the rod about 5-6 times. This will remove any lime deposits. Then flush out with 2-3 decanters of water. You can obtain a new manual by calling customer service or going to the website-www.bunn.com going to @home, then products-click on your brewer-and then select use and care manual and you can print it out or view it online.
Anonymous
  • 16 Answers
  • Posted on Mar 08, 2011
SOURCE: My coffee maker takes 20
The first suggestion is de-calcify as the heating element is probably coated. The following should explain what I mean.
Most likely you have calcium flake deposits clogging the orifice/jet/valve, that restricts the flow of water until heated properly. As the water starts to flow the flakes collect and block the water flow. Periodic cleaning will cure this and prevent damage to the, orifices, jets,valves and heating elements of your machine ( as calcium builds up it tends to insulate the heating element thus requiring more energy/heat to complete the task). Eventually the heating element will over heat and burn out. Periodic cleaning extends the life of the machine plus the added bonus of a better tasting " Cup of JOE".
Most any cleaning preparation designated for a "Mr. Coffee " type machine will do the job. If you want a home remedy 3-4 tablespoons of white distilled vinegar per cup of water ( calculate for the size of your water reservoir ). But please do it outside on the patio, as the vinegar tends to be in competition with the air freshener, and will win.
sincerely,
Doc Michael
Gaggia titanium coffee slow coming out of machine
You probably need to clean or replace the screen inside your brew unit. I recently just cleaned mine due to the same issue with some steel wool.
Hot water is comeing out of the spot slow
delime the sprayhead holes with a paperclip, and the trough drain inside the top with a screwdriver. this will ensure proper flow
1helpful
Nespresso slow water
Hi there coffee-friend
I think the machine needs a bath or rather cleaning.
The machines have to be cleaned with a certain interval according to use.
The manual tells you how to clean this particular machine.
If you do not have the manual at hand there are usually good directions on the cleaning fluid.
enjoy your coffee
kolbrun
1helpful
How do you descale the kerig?
You must buy a descaling liquid at any big grocery chain. Then add the right amount of cleaner with water in the tank.Set the machine thru a descaling mode or just run a few cycles without coffee thru the machine. Then i would just run clean water thru a few cycles just to clean any residue left from the cleaner. If your using any type of bottled water when you make coffee, I would just use tap water, this will slow down the scaling process.
good luck
Water come out slow
mcdevito75 here, Souds like it needs cleaning, Water will leave deposits in the brewing ports that have to be cleaned, follow the owners manual on cleaning.
Hot water comes to slow
It sounds like your water line may be clogged. Buy some descaler powder and follow the instructions on the package to clean away calcium deposits from inside your coffee maker's water lines.
Brew is slow coming; i have awire instrument but
you have to remove the "nozzle" where the water comes out. It is threaded in so it is easy to remove and re-install. Then run the wire cleaning tool right up the now exposed hole. That will clean it out. Hope I was able to help.....
1helpful
My GE coffee maker is very slow making a pot of coffee I need to clean it. Its digital
run some vinegar thru it a couple of brews and see if this speeds up the water, you will want to run a third brew of plain tap water to rinse vinegar taste out
The machine is only a couple months old. It is
check grinder maybe is too fine ,go litlle bit courser and try
Flakes of stuff in spray head
clean the tank with white vinegar
pour it in and wait 15 mins, than pour 4 or 5 pots of water thru it
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
