Toshiba BDXK100KC Blu-ray Player Logo
Shaun Mackey Posted on Dec 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model bdxk100kc blu-ray player won't even play any discs...keeps saying loading, all wiring to correct ports, cleaned discs...what else can we do???
Vinho Xie
Level 3:
Genius:
  • Toshiba Master 1,419 Answers
  • Posted on Aug 06, 2021
Vinho Xie
Toshiba Master
Level 3:
Genius:
Answers
1419
Questions
0
Helped
413760
Points
4431
Blu-ray Disc Association (BDA) said blu-ray Discs with capacity up to C will not be compatible with existing blu-ray players. Although manufacturers such as Sharp and TDK have developed 100-gigabyte blu-ray discs, these large-capacity discs are impractical at this stage because existing Blu-ray players cannot handle discs larger than 50GB.
Why don't you play blu-ray on PC. It's quite easy and what you should do is to read disc with drive and play it with free Blu-ray player software. Here is the recommendation. You can have a check.
www.leawo.org/blu-ray-player/?fixya=1410
Nanny
Level 3:
Genius:
  • Toshiba Master 2,351 Answers
  • Posted on Jan 19, 2020
Nanny
Toshiba Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988567
Points
7262
What you need to do is to reset your Blu-ray player in the first place.
1. Remove the Blu-ray disc from the Blu-ray player' drive.
2. Power off the Blu-ray player and disconnect wire.
3. Unplug the Blu-ray player from the output TV and disconnect the cable.
4. Wait in patience and remain the Blu-ray player power off for minutes.
5. Plug the Blu-ray cord and connect the Blu-ray player with to the TV.
6. Power on the Blu-ray player.
7. Insert the Blu-ray disc to the player one more time.
For more details for the solution, you can check on this tutorial:
Why Won't My Blu-ray Players Play Blu-ray Discs
Abby Loov
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 25, 2014
Abby Loov
Contributor
Level 1:
Answers
Questions
Helped
343
Points
I'm having the same problem with regular dvd's. it'll play blu-rays o problem
2answers
My ps3 plays games but will not play blu ray movie
You can try clear your movie data from the discs you\'ve played (according to Fox that\'s sometimes the culprit when a disc won\'t even load): restart your PS3 and go to the video menu and scroll up to the BluRay Data section. Go into it and check that it has saved some info for your movies. Now deleted all the data in this folder except the shared data crap, and hopefully your movies start perfectly!!
If that fails try the following:
In the XMB(menus) go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI). Turn that off. This has also been known to work.
1helpful
2answers
Disc won't load
Try a different disc, one that worked before if problem still persists try and buy a lens cleaning disc that should solve your problem. If not, your optical laser head needs replacing.
2answers
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
2answers
My vizio vbr120 will play dvd but not blu ray
This is a common problem in blu ray discs, the reason why it won't play is because they play at a faster speed and demand a higher precision to produce the high definition signal required to play the program. The only way to fix this is to replace the whole laser pickup assembly which would not be cost effective.
3answers
My Denon DVM-1800 says no disc what do I do?
I have had the same thing happen with my blu-ray. I have tried cleaning the disc; the lens, occasionally with success. flashing the bios. also known as update of the system [can be done online {if equipped} of mine also has a usb port {download the correct file to a USB drive and re-power DVD with the drive in place}]. if these things don't work try manufacturer tech support. I had mine replaced because it wpould NOT flash. good luck.
I received a freebie DVD player but it won't play DVD it keeps saying no disc
The problem is in the laser pickup assembly, buy a DVD cleaning kit and follow instructions, it may help buy more time if not! replace the player not cost effective to repair.
2helpful
2answers
No matter what DVD I load in the player, it won't play the DVD. It says "Cannot play this disk". What's the problem?
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
2answers
Our blu-ray disc player bdp-s300 won't play newest blu-ray
Go to web site below. www.blu-ray.com/firmware/firmware.php?id=23 - 4 hours ago
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
