Schaerer Siena Espresso Machine Logo
Bernard Wohlforth Posted on Dec 29, 2012
My shaerer machine (ambiente) is giving error, selection locked, heating steam. Need help. Thanks.
markybean
Level 1:
Habit-Forming:
New Friend:
  • Contributor 42 Answers
  • Posted on Mar 24, 2014
markybean
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
42
Questions
Helped
24425
Points
91
This is quite common on steam boiler when the level probe is not reached within a specific period of time. Reason is due to limescale buildup which restricts water flow...
You need to remove and descale the fill pipe to the steam boiler. If its very badly blocked, you can drill out the blockage with a 7/8mm drill bit and then leave it soak in descaling solution until its clear and you can blow through it. Also you will find a small restrictor between fittings somewhere back from the fill pipe (between the fill pipe and the fill valve). This is a small disc shape with a 0.8mm bore in the centre, you'll need to check that this is clear also, they are notorious for blocking up due to small size. You can clear this using some very fine wire or if you have the Schaerer expander baffle pen. Be careful not to lose this restrictor when loosening the brass fittings as it is extremely difficult to find if you drop it into the machine. Good luck
  • ROMAS
    ROMAS Sep 29, 2018
    Thanks for help, found a small disc shape with a 0.8mm bore in the center blocked. See picture
  • markybean Oct 03, 2018
    Great, glad to see you found and cleared the blockage. Did this manage to fix the problem? If not please let me know. The Ambiente is one of the finest machines Schaerer ever produced and one of the most reliable.
1 Related Answer
Anonymous
  • 26 Answers
  • Posted on Nov 10, 2010
SOURCE: My shaerer expresso machine (ambiente) is giving
"level steam probe" occurs when it takes more than two minutes to fill the water in the steam boiler. The easiest solution is low water pressure to the machine. Does it have a water filter? replacing it will probably help. Other problems could be the fill valve is not opening fully and or scaled water lines going to the steam boiler. The first thing I would do is activate the hot water tap and look at the pressure. If the water is coming out slow then I know its a restriction to the machine.
Can you help me fix my faema x30 coffee machine not heating one boiler thanks
Hey, Check the power supply and make sure it is connected properly before attempting to fix your Faema X30 coffee maker's non-heating boiler issue. Next, check for any flaws or malfunctions with the thermostat and heating element. If necessary, think about swapping out the defective parts or hiring a pro to fix it.Thanks!
I have a Shaerer Ambiante Espresso Machine that is giving the "select beverage, heating steam" error message. What does this mean.
Please descale the machine. Make sure you are using authentic descaling product. There are many unscrupulous products labeled as descaler but contain Baking soda only.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
2helpful
Schaerer ambiente display saying" selection locked
the machine seriel number and or cust, number are missing you need a " service card or the machine " save data card "
2helpful
2answers
My shaerer expresso machine (ambiente) is giving error, level steam probe, when this happens it will not steam. This problem does not happen all the time and can be cleared by shuting machine off then...
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
hello,
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
thanks.
6helpful
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
How do I programme the Siena coffee machine?
I dont know what model of coffee machine you have but I have a link for you Mr. Giovanni,kindly click the link below and choose what model you have then download the manual.
http://www.schaerer.com/download/default-n106-sE.html
If you find this helpful please dont hesitate to vote my answer.Or need any clarrification I can assist please comment this answer.Thanks and God bless.
2helpful
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
2answers
GE microwave model jes1456 has sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Top Schaerer Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Liza Cat V
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
