After the orange flashing light during charging the light turns green indicating full charge. When I try to use it nothing happens. no lights no beeps. nothing.
SOURCE: light flashes but won't turn on
The Roomba's internal charging system is not working. In this situation, a replacement Roomba is necessary. You can call 1-877-855-8593 to find out what your options are. There's a discount for Roomba owners who need replacement units.
SOURCE: 560 backs out of charging base then only turns in right circles
Yes, this is known issue and if your bumper moves freely, you might be
facing a sensor fault caused by poor quality of components.
Here is a
guide to fix it
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have
fun
Avi
SOURCE: Roomba 530 Robotic Vacuum: I've cleaned everything, roomba is charged, and ye...
have you poped out the front wheel and cleaned the axle.also pull the 2 roller brushes out and pull the funny looking yellow ends off .clean hair ect. out n reinstall
SOURCE: My Roomba 560 does not charge - Rapid orange flash
Battery problem.If the battery is absolutely new,still it can be battery problem.But if the battery is old then replace the battery.To confirm the battery fault check the voltage of battery with meter.It should show exact volt.At least 12 volt.If the battery gets warm then the charging circuit is working but if not then the charging circuit is not working.failure is due to a failure with U2/U4 in the charging circuit.
For more troubleshooting,if you require service manual for your roomba model,please click on this link directly:---
http://choisirsonaspirateur.info/wp-content/uploads/2010/03/Roomba-500-Series-Service-Manual.pdf
Thanks.
keep updated for any more query.you can rate this solution and show your
appreciation.
