SOURCE: Cobra 38 WXST Handheld - Which is positive on DC connector?
To my knowledge, it is positive. To confirm, pls look closely at the markings beneath the DC power jack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
SOURCE: can I take phinals out of my cobra 29 mobile and
no it has two finals because its a high power radio...you get side band by your crystals not finals...and yes you should be able to change out the finals...the best one to install in it is 1969 if you can find them.
SOURCE: Hi i gotta a home base cobra cam 89 lights when
Cheap fix.....small inexpensive light bulbs. You may want a tech to do it. Take the cover off and you will see them. $5-$10
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
SOURCE: Is a Cobra HH 38
Regards,
Tony
