Washing Machines Logo
Philip Devole Posted on Dec 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Morgan Wynne
Level 2:
Scholar:
  • Expert 133 Answers
  • Posted on Dec 29, 2012
Morgan Wynne
Expert
Level 2:
Scholar:
Answers
133
Questions
Helped
29974
Points
412
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jun 17, 2008
SOURCE: CLOTHES STUCK IN WASHER!!!!!!
http://www.consumeraffairs.com/homeowners/maytag_wash.html
sgcolem
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Anonymous
  • Posted on Oct 10, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
duby1990
Justin Duby
  • 370 Answers
  • Posted on Nov 18, 2008
SOURCE: SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Anonymous
  • Posted on Nov 30, 2008
SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
screwturner, I had the exact same problem took the pump completely apart and found a nickel caught inside the drainback flap inside the pump. after having to wash clothes at the laundromat for a week I'm so thankful to find your solution worked. You're the best
My Neptune is shutting down with a SUDS error
If machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
1helpful
2answers
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
3helpful
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
1helpful
7helpful
4answers
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
