Is it in the recalls my coffee maker nu. c-05158 lr 25059 bunn omatic r
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
SOURCE: My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
SOURCE: My Bunn Pour-Omatic Coffee Maker leaked all over
Do you have the model and date code located on the bottom of the brewer? If you will call Customer Service at 800-352-2866 we will be able to assist you in resolving this problem.
SOURCE: My bunn omatic coffee maker is putting out too
More than likely could be a bad timer.Check the time of the brew cycle is consistant each time.See if the sprayhead is in place.You may also try rodding out the brew tube with a de-liming spring p.n. 1111.0000.
SOURCE: We have an older style
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
