Hi, I'm having a similar problem two what's listed in the two postings below, but neither posting says what the fix was, just thanks for it... Anyways the problem is if I turn off the TV and turn it back on either five secs or five hours later the image will split into three separate, overlapping images of red, blue, and green within 2 secs to 5 mins. The only thing that stops this is leaving the TV on all the time and just turning off any input when I'm not wathing so that the screen will go dark and the sond cuts out. I figure this will burn out the lamps prematurely since they don't actually trn off when I do this, not to mention if I have a power outage it starts all over again anyways. The only way to get the mages to come back together is by continually turning the unit off & on for anywhere from 30 mins to 3 hours, and even after 3 hours t doesn't always work. Please HELP!!! Thanks!
-Leigh Clow
[email protected]
Hitachi Mo# 53uwx10ba double image
var g_tryMail = 0;
function addthschng()
if($i('at_email') != null)
addthis_sendto('email');
else
g_tryMail++;
if(g_tryMail
Report abuse
shared by 33 users
posted by amking on Dec 03, 2007
on my Hitachi Mo# 53uwx10ba I developed a slight double image on about 25-30% of the left side of the screen the rest of the picture is clear and good. convergence goes through its motions but does not correct problem,Have unplugged unit over night,tried different cables..there are manual controls behind front panel that adjust color and clarity but will not will fix proplem ..Please suggest resolution,
Thank you for your time as it is appreciated.
Al
Comment posted on Dec 11, 2007
Right on the money that was the fix!! Thank you is not enough but it keeps me believing that together in this great nation anything can be done if we do it together. strike one more positive for humanity.
Replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
