Sony VAIO VGN-CR220E/P Notebook Logo
A
Anonymous Posted on Dec 29, 2012
Sony vgn-cr590 drivers mass storage - Sony VAIO VGN-CR220E/P Notebook
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Jul 12, 2009
SOURCE: I need driver for sony vaio vgn-cr590 motion eye
this is the link  http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR590&upd_id=3586&os_id=29
Anonymous
  • 1738 Answers
  • Posted on Aug 11, 2009
I would go to www.sony.com and click on service and support on the website in the space after the word model put the vgn-cr590
asingh1225
Amar Sondhi
  • 122 Answers
  • Posted on Dec 14, 2009
SOURCE: Sony Vaio VGN-FE770G windows 7 upgrade problems
hello, try the link below;
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
the driver above is for vista and should work with windows 7.
I hope this helps.
Kind regards,
Amar Sondhi
Bob Dizon
  • 48 Answers
  • Posted on Jan 20, 2010
SOURCE: DVD-RW of Sony vaio VGN-CR590 don't still run after changing win7
About the link you need to download the driver for your DVD-RW drive, have you tried the Pioneer website?
Anonymous
  • 112 Answers
  • Posted on Jun 24, 2010
SOURCE: hi, i use latop sonyvaio vgn-cr220e
Install the Memory card Driver for windows vista to resolve the issue as the Driver for the Windows vista will work with windows 7 OS.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3044&os_id=28
My Sony VGN-CR590 shuts down after 5-10 minutes. How can this be fixed? I'm not sure the fans are running.
A way to check to see if the machine is overheating is when you turn on the computer, there should be an option to hit F10 or F2 for the bios. In there, there should be a few temperature readings. Let the machine idle and in the bios if the tempature rises in there there could be an issue with the cooling for the CPU.
Doesn't have a mass storage controller for my laptop sony vaio vgn-n220e
If memory serves me, the mass storage controller is part of the chipset software. Here is a link to the driver download for you laptop. Choose the OS, and then look under motherboard for the chipset driver. While you are there, you might even update all your hardware drivers.
http://esupport.sony.com/US/p/model-home.pl?mdl=VGNN220EW&template_id=1&region_id=1&tab=download#/downloadTab
Hope this helps
Dear Sir, Please send me mass storage device driver for my laptop sony vaio vgn b100b.
I couldn't immediately find your model number on the Sony support site so please double check that it's correct and then select your model number from the drop down box or enter your serial number at this link in order to view the available driver downloads for your laptop. You may find that the mass storage device driver is bundled within one of the main Intel executables.
I have a sony vaio vgn-sz491n. i have loaded windows 7 professional, 64bit onto it. in the device manager, it shows that a driver for a mass storage controller is missing. where can i find this...
Most likely missing a driver for SD/MC card reader
The problem is that Sony doesnt offer drivers for 64-bit windows so the other 32-bit drivers will not be compatible.
You have the options to install the windows versions supported by sony from esupport.sony.com (Vista or XP)
Or try installing windows 7 32-bit and installing the missing drivers from esupport (Vista section) as usually they are compatible.
If the driver is still missing you will need to update the driver from device manager (previously installed from esupport) and then select to browse or select a location, which will be %temp% or what is the same the temp folder for your account C\users\your_user_name\appdata\temp. This folder is usually hidden but it will work if you just type %temp%
Mass storage device driver of sony vaio vgn-n365e for windows 7
The drivers for Windows 7 are not released by Sony. However, my experience says installing the Vista drivers will do the trick. I will tell you which all drivers to install in the computer to for mass storage device. Please install the drivers in the same order:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2653&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2663&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2670&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN395E&upd_id=2818&os_id=28
Thanks!!!!
1helpful
4helpful
2answers
I need driver for sony vaio vgn-cr590 motion eye driver. please help me send to [email protected]
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
