Has taken wii points but won't give up the dance . Says there's a problem connecting to the internet.
SOURCE: wii internet connection
This is appearantly a common problem with the Wii. I got this information right off their Support Website.
Error Code: 50231
The Wii console's internet connection settings have not been configured yet. In order for the Wii console to connect online, you must first go through a quick setup process to connect to your home network.
If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
I hope this takes care of your problm.
SOURCE: Games Won't Load
i have had the same problem for some time and have just about had enough and was going ot take mine back to where i purchased it . as a final try i took it off the stand and laid it flat so cds went like a normal player and my games including sports have worked everytime i would give it a try has it seems the wii has a problem with some disks when on its side
SOURCE: error code 109144 when try to connect to internet via wii console
Error Code: 109144
There was a problem registering the console to the WiiConnect24 service. What to do:
SOURCE: Okay, in the Nintendo Wii I go to the Wii Shop
Try changing your channel on the router to 11 or 1. For Linksys
WRT54G routers enter the ip address of the router (default is
192.168.1.1) enter password and user name (default is admin/admin) then
click wireless tab, now select a different wireless channel from the
drop down box. Fix is not guaranteed to work for all consoles. source
I was having a big problem with those two errors, when I realized
that the WEP encryption has to be set on Key 1 in order for the Wii to
recognize it. It\'s the same with the DS.
I would like to add to the information you have posted that on top
of what you have posted, I had to change the MTU value from 0 (Default)
to 1500 witch it was in the router for the Wii to finally connect and
download the updates. (via email, thanks Jose
Solution 2:
The console of my girlfriend had this error code and none of your
solutions could help, but I found another one: I had to put in the IP
manually because the Router's DHCP-Server didn't work.
Solution 3:
I originally received the 52030 error code, followed the directions
from this site but could only get MTU to 1492 (Linksys 802.11B router,
too lazy to look up the number).
Connected for about 5 minutes, was downloading the update, got to
100% then gave me the same error code. Went back in, recreated the
connection, worked, went to download update, this time it got to 60%
and just stopped. My ISP was fine but the download simply wouldn\'t
progress. Hardbooted the Wii, reset the internet connection and
nothing. Tried multiple times with same result, Error Code 52230.
Had been having other problems with my router so I figured that was
the source, headed over to Wal-Mart (yippy!), picked up a Linksys
802.11G router, plugged in and everything worked without a hitch.
Moral of this story...buy a new router and plead to your significant
other, But honey, look how cool the Wii-Weather Channel is! later.
TOTALLY worth it.
Solution 4:
I love my Wii. The only thing I hated initially was the network
setup. I kept getting the error code 52030. I have a DLink 624 router
(hardware reversion C). I fixed my Wii connection problem by upgrading
my firmware to 2.76 and setting the wireless router setting to SuperG
without Turbo on Channel 11.
SOURCE: My Wii will not conncet
Netflix is down at the moment. my PS3 won't connect right now either. On the plus side, the last time this happened, they offered me a discount. =)
