Toshiba 36A43 36" TV Logo
Posted on Jan 17, 2009
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting changes. Model Toshiba 36A43.
  • sgiambroni09 Jan 25, 2009
    I have a similar problem only that my up and down channel buttons don't work and i need to know how to fix it. thanks!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4358
Points
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
TV Sharp LC-40LE830U. My front panel ys disabled and my remote control don't work. I can power on/off only. How can I enable my front panel without use remote control? or reset factory settings?
If both your front panel and remote control are disabled, the best option would be to perform a factory reset to restore the TV to its original settings.
To reset the Sharp LC-40LE830U to factory settings:
  1. Unplug the TV from the power outlet and wait for at least 60 seconds.
  2. Press and hold the power button on the TV for 5 seconds while the TV is still unplugged.
  3. Plug the TV back in and turn it on using the power button on the TV itself.
  4. Once the TV is turned on, press and hold the "input" and "volume down" buttons on the TV simultaneously for 5 seconds.
  5. The TV will then enter the service mode menu.
  6. Press the "menu" button on the remote control to navigate through the menu and select "option."
  7. Select "factory reset" from the options menu and follow the on-screen instructions to complete the reset.
Note: The factory reset will erase all custom settings, including parental controls, picture, and audio settings.
How to shrint screen
Hello, AE -
Are you asking how to make the picture on your TV smaller ("shrink it")?If so, without knowing the make and model of your particular TV, I can only give you general instructions.
You will need the remote control which came with your TV (not a remote control for cable or satellite dish TV service.)
Turn the TV ON.With the remote control, press the MENU button. One of the MENU choices which displays on the TV screen should be SETTINGS or SCREEN RESOLUTION. Choose that.
You will be provided a list of screen image sizes. Move through each option to determine which size you prefer.Once you have landed on the screen aspect ratio (another term for picture size) you prefer, press the OK button on the remote control. Choose to keep the chosen setting and EXIT or ESCAPE the MENU options.
Best wishes.
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
1helpful
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Menu is on screen and tv wont do anything
try a hard reset first - unplug tv from power source and all cables for about 1 hour, reconnect everything and see..
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
1helpful
2answers
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
