Rear doors open from outside but not inside. Is there a child safety switch somewhere?
SOURCE: Volvo s40 rear doors wont open inside or outside
There is a child safety switch on the rear latch assembly that prevents opening from the inside handle. This switch may be on. Check your owners manual for more info.
Bret
RepairPal.com
SOURCE: rear doors & windows
Check to see if you have child protection locks on them if that is the case turn them off? Please rate my response Thank you very much
SOURCE: my 2004 Volvo S40 Drivers Side Door will not open
the handle might of broke internally, theres a rod and a clip that gets attached to the handle. i would take the door panel off and visual look at the latch mechanism and the rod that goes from that to the outside handle
SOURCE: volvo xc90 rear hatch door closed and won't open
Hold the hatch hard closed into its frame whilst pulling on the release handle. The mechanism on most cars consists a grab/release on the door and a simple metal hop at the bottom of the frame. Over time the hoop can become loose and move slightly inwards each time the door is shut. The door seal rubbers push back on the door surround putting a lot of tension against the grab/release mechanism preventing it from releasing. By pressing on the door and compressing the rubber surround you will take the pressure off the release mechanism and allow it to open when you pull on the handle. Once the door hatch is open, loosen the mounting bolts to the metal hoop and move it out about 10mm. Tighten the mounting bolts. Shut the door gently as a trial close and check for security of fit. If very slack, ease the hoop inwards a couple of millimetres. When happy, tighten the mounting bolts securely. draw around the hoop mount with indelible ink so if it moves in future you have early visual warning and can remount it easily
SOURCE: My rear left door will
Remove the interior door trim and check the linkages from the door handle to the lock.. This is a known issue as the plastic clips which hold the linkages in place harden with age and eventually fail allowing the linage rods to fall out !! Replacing the clips and refitting rods will solve the issue..
http://www.howtorepairguide.com/2013/02/honda-pilot-rear-door-lock-wont-open.html
This will help.
Thanks.
