When i hook up my sound system anything i play sounds like chipmunks
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
SOURCE: Compaq Speakers Sounds Like Alvin and the Chipmunks
I had the same problem and found this post on another site. It worked like a charm.
Dude Check It. i just fixed mine.. go to the main menu and go to sound effects you will then find a area that says karaoke put that on #0 and that should fix your problem..
This post has been edited by VoLt: Oct 8 2008, 11:51 AM
SOURCE: distorted sound (voices sound like "Alvin and the Chipmunks"
Have you tried another set of speakers? If not I would do so cause your speakers might have just gone bad!
SOURCE: people in any videos I download sound like chipmunks
I am having a similar problem on my other computer. My son installed an old microphone we had from a windows98 computer and suddenly audio stuff sounds like Alvin and the Chipmunks. I tried our windows troubleshooter thing and set our accelleration to basic which helped Window media, but Youtube and whatever the other media thing that defaults when my son clicks on "my music' songs, are still distorted.
We tried unplugging and plugging in the mic again - a green 'realtek' box showed up. I thought about uninstalling it to see, but wondered if this is something that affects other parts of my computer.
SOURCE: Streaming audio sounds like chipmunks. Way off
Could either be the quality of the file. If the file was uploaded at bad quality, you'll receive it at that same quality. However since you are streaming, and several persons might be streaming the same file. The server you are receiving the file from could be under stress or your internet connection is being used by other program.
Check your computer and see if any other program is using up your bandwidth.
SOURCE: PC Speakers sound like chipmunks.
try disconnecting the speakers and the other stuff like mic camera and only plug the speakers in if it doesn't work get new speakers
