just hold down the menu button for 30 seconds then tap it repeatedly 20 times a few screen flashes should pop up then 5 minutes later the screen should show up
The main power regulator board has the fault. It might need replacement as card basis. Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
In PLAYING mode, press M while playing music to enter
the selection menu screen.
Choose Repeat and press M to enter the Repeat menu screen.
Next go to Random using |<< / >>| buttons, while selected Random, press M to choose for random play.
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
It's in the friggin manual:
You can set your player to play songs randomly (Shuffle All ) or repeatedly (Repeat
One or Repeat All ).
1 From the main menu, select > Play mode.
2 Press 3 or 4 to scroll up or down the options.
3 Press 2 to select an option.
While you are playing music, you can see the above active play mode screen.
When I turn on my TV
it goes straight to the menu screen. You can still hear sound but no
picture. When I try to exit you see the picture for about a second then
it automatically flashes back to the menu screen. Even if I try to use
the functions in the menu screen it flashes right back to the main menu
screen. Very frustrated...need help!
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
Repeat All ).
While you are playing music you can see the following active play mode screen.
