2006 Pontiac Torrent Logo
Bruce Wilson Posted on Dec 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace water pump torrent
Procedure to replace
Jonah Oneal
Level 3:
  • Pontiac Master 14,092 Answers
  • Posted on Dec 30, 2012
Jonah Oneal
Pontiac Master
Level 3:
Answers
14092
Questions
0
Helped
7235813
Points
44533
Drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Pump Products
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 17, 2022
Pump Products
Contributor
Level 1:
Answers
Questions
0
Helped
3188
Points
6
Benefits of Goulds Pumps
The quality of the Goulds brand, which is respected and known internationally and is offered in more than 150 countries, speaks for itself. Although Goulds is renowned for its high calibre products, its wide range of offerings is truly astounding.
Since Goulds pumps have been available for many years, you may be sure that their quality has endured. Additionally, you may be confident that they have kept up with developments in pump technology. For a good reason, Goulds is one of the greatest brands in the market, and when you purchase one of their pumps, you can be confident that you're getting a high-quality answer to your pumping demands.
Goulds Pumps has a reliable and long-lasting solution for all your pumping needs, whether you have a wet basement that needs a sump, an ancient well with an antiquated pumping system, or you're a builder with a sizable pumping project. Their pumps undergo extensive testing and must adhere to tight pressure, temperature, corrosion, and abrasion requirements. And Goulds Pumps is the only process pump manufacturer in the market equipped with digital monitoring.
https://www.pumpproducts.com/brands/goulds.html
Am having constant overheating what is the solution
you replaced a water pump and its leaking. fix this first. did you install a new gasket. make sure all the air is bleed out of the cooling system and make sure the cooling fans are working at the rad.
99 olds intrigue blows out clod air nd has leak in water pump
The water pump has to be replaced.Also inspect timing chain.Many a times while replacing water pump timing chain also gets misaligned.
Also loose overstretched timing chain causes water pump issues:-----
For complete water pump replacing procedure, step by step, there are few help links.I suggest you to refer the help links.
Click the link below:-----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile Cutlass Ciera?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
These will help.
Thanks.
Replace water pump
For complete water pump replacing procedure,step by step,there are few help links.I suggest you to refer the help links.
Where is Water Pump located on Toyota Corolla? http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
These will help.
Thanks.
Replace water pump
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
This will help. Thanks
How to replace water pump infiniti m35 2006
This will help. Thanks.
Water pump replacement
Replace t-state from water pump
How to route Water Pump Belt?
1helpful
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
Installation Procedure
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
