Acer Power FH  PC Desktop Logo
Posted on Dec 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On starting my Acer PC , it is switched off aftre one beep. No BIOS display
Brian Sullivan
Level 3:
  • Acer Master 27,725 Answers
  • Posted on Dec 28, 2012
Brian Sullivan
Acer Master
Level 3:
Answers
27725
Questions
Helped
5669954
Points
79191
One beep Normal POST, computer is ok.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Hope this helps.
max carson
Level 3:
  • Acer Master 7,627 Answers
max carson
Acer Master
Level 3:
Answers
7627
Questions
Helped
1015188
Points
21773
How old is the computer? Have you changed the CMOS battery? Reseat Memory Mods,possible bad Memory mod. May be a bad PSU. Try Acer support , Troubleshooting procedures. If it on in years the PSU is a likely place to start. Do you have a Multimeter to verify voltages. If , when you push the on/off button the fans spin, the LED's blink, and then a shut down, all power off. Power supply, system board, keyboard. Take a look at the Beep Codes: http://www.bioscentral.com/beepcodes/phoenixbeep.htm# That should keep you busy for a while.
4 Beeps on my Acer X1935 and then nothing, no display
maybe you check on Rams, sometimes BIOS battery
1helpful
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
2helpful
2answers
When i turn on my acer travelmate341 the screen has no display and i heard 2 beeps. what could be the problem and how can i fix it or check whats causing it.
if you dont get any msg or charecter while switching on then i guess the motherboard is out...2 beeps denotes no response from Motherboard CMOS/BIOS chip...
if you can see some msg then the LCD screen may be out...
the option is to get the MB changed
No display of cmos program at a very start
Here's what you do: Press F2 at initial startup holding the button down until it goes into BIOS or beeps @ you. When you get into the Bios, choose to reset BIOS defaults. Restart system.
2helpful
Acer Aspire One continuous beeping at power on, until Windows screen comes on
Need to check the BIOS beep codes but I'm fairly sure that continuous beeping on boot is a display adaptor card issue. If you don't see anything on the screen until that point it may be something is set wrongly for the display within BIOS and it can't sort it out until Windows takes control of the system.
1helpful
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Screen went out on my Acer Aspire 5102WLMi
as per your information your display adapter(if onboard) or video card is defective.replace it
No beep no display but fan is steel moving
Hi Rajesh_KS
How many beeps did you hear? It matters. Every Bios has a name. (Award, AMI, Phoenix, IBM ect).
You'll need to enter your bios & check the name. It will be at the top of the menue or you can catch it just as your PC starts up.
Once you know the name of your bios & how many beeps you hear, Ex: 1 long 2 short & repeating. You'll know just what the problem is with regaurds to the memory.
I'll post a link for bios beep codes. All you'll need is the name.
Regardless of the error, it's suggested you remove your memory & than re-seat it. You will not get video display if your memory has a problem.
Here's the bios link: http://www.bioscentral.com/beepcodes/awardbeep.htm
On the right side of the page other manufactures bios's are listed & each have their own code system.
Support link for your Acer:
http://support-web.acer-euro.com/app/csd/etkdb.nsf/4b7a708d8dbc41cdc1256bd6003c0165?SearchView&SearchView&Query=Veriton%207700G&start=1&count=10&seq=1
You can also test your memory if re-seating did not help.
Go to this link:
http://www.memtest.org/
Scroll down till you see ** Memtest86+ V2.01 (21/02/2008) **
all typed in red. You can download a bootable CD program to test your memory. File; Download - Pre-Compiled Bootable ISO (.zip)
If you rather use bootable floppy disk, File; Download - Pre-Compiled package for Floppy (DOS - Win)
Good luck & Kind Regards!
please vote ;-}
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
