1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
You can't post conmments that contain an email address.
PDF
For Great Northern Popcorn Company Models: 6000 Roosevelt Full ... 4OZ POPPER ASSEMBLY. Model No.: UE40010. Voltage: AC 120V-60Hz. Input Power: ...
I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
three parts corn to one part oil. so 6 oz corn to 2 oz oil. if it takes over 4 min. in a hot kettle (if its heating rite) its too much for it, if its done under 3 min. not enough .
Gold Medal Model number 2012 is for a 28x48 4 wheel cart only, it is not a popcorn machine.
Astro Pops are model 2010, have been for 30+ years.
Their Manuals are not publicly available because they have changed many, many times and the odds of you getting the correct one is slim.
What parts are you looking for? and what is the manufacture date of the machine?, the serial plate is in the lower right hand corner of the cabinet, behind the cart doors if there are doors.
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt. 1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
