Wen computer comes on it said error with windows windows is shuting down what can i do from bio or boot set up to put it back to factory settingshelp
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
SOURCE: still trying to restore my emachines comp. tried
This error can show up during installation of the operating system either via the hard drive (the restore feature is located on the hard drive and shows up as a drive letter under My Computer) which indicates that you have bad memory,
OR
You are installing from a DVD or CD, in which case it could be either bad memory or a bad disk.
good luck
tony
SOURCE: does my w3507 have an agp port
I found the specs below on their website. Sorry only a PCI Enhanced port, NO AGP. Hope this helps. Best Regards, -md
CPU :
Intel® Celeron® D Processor 352
(3.20GHz, 512KB L2 cache, 533MHz FSB)
Operating System :
Genuine Microsoft® Windows® XP Media Center Edition 2005
Monitor :
Includes eMachines® 15.4" Widescreen LCD Flat Panel Monitor
Chipset :
ATI Radeon™ Xpress 200
Memory :
512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
Hard Drive :
120GB HDD (7200rpm, 2MB cache)
Optical Drive :
16x Multi-format Dual-layer DVD±RW
Media Reader :
9-in-1 Digital Media Manager™ (Memory Stick®, Memory Stick Pro®, MultiMediaCard™, Secure Digital™, CompactFlash®, MicroDrive, SmartMedia, xD-Picture Card™, USB 2.0)
Video :
ATI Radeon™ X200-based integrated graphics
Up to 128MB of shared video memory
PCI Express (PCIe x16) slot available
Sound :
6-channel (5.1) high-definition audio
Network :
10/100Mbps integrated Ethernet LAN (RJ-45 port)
Modem :
56K ITU v.92-ready Fax/Modem (RJ-11 port)
Peripherals :
Standard multifunction keyboard, 2-button wheel mouse, amplified stereo speakers (USB powered)
Ports/Other :
5 USB 2.0 (1 in front, 4 in back), VGA External Connector, serial port, parallel port, 2 PS/2 ports, 5 audio ports (2 in front, 3 in back)
Dimensions :
14.25"H x 7.25"W x 16"D
Weight :
22.5 lbs
FYI - PCI Express (Peripheral Component Interconnect Express), officially abbreviated as PCIe (or PCI-E, as it is commonly called), is a computer expansion card standard designed to replace the older PCI, PCI-X, and AGP standards. Introduced by Intel in 2004, PCIe is the latest standard for expansion cards that is available on mainstream
E-machine w3507 specs:
CPU : Intel® Celeron® D Processor 352
Operating System : Genuine Microsoft® Windows® XP Media Center Edition 2005
Monitor : Includes eMachines® 15.4" Widescreen LCD Flat Panel Monitor
Chipset : ATI Radeon™ Xpress 200
Memory : 512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
Hard Drive : 120GB HDD (7200rpm, 2MB cache)
Optical Drive : 16x Multi-format Dual-layer DVD±RW
Media Reader : 9-in-1 Digital Media Manager™ (Memory Stick®, Memory Stick Pro®, MultiMediaCard™, Secure Digital™, CompactFlash®, MicroDrive, SmartMedia, xD-Picture Card™, USB 2.0)
Video : ATI Radeon™ X200-based integrated graphics
Sound : 6-channel (5.1) high-definition audio
Network : 10/100Mbps integrated Ethernet LAN (RJ-45 port)
Modem : 56K ITU v.92-ready Fax/Modem (RJ-11 port)
Peripherals : Standard multifunction keyboard, 2-button wheel mouse, amplified stereo speakers (USB powered)
Ports/Other : 5 USB 2.0 (1 in front, 4 in back), VGA External Connector, serial port, parallel port, 2 PS/2 ports, 5 audio ports (2 in front, 3 in back)
Dimensions : 14.25"H x 7.25"W x 16"D
Weight : 22.5 lbs
SOURCE: I accedentally knocked the power wires off inside
Power On switch, (Button), wires from the front panel that go to the motherboard?
I could really use the name of the motherboard, to try to get you this information.
I don't have an eMachines W3057 sitting in front of me, at the moment, and eMachines Support never states what motherboard is being used.
Usually they are made by TriGem, or ECS, or Intel.
HOWEVER, (Not shouting), from my data bank of information, it is stated that the motherboard used in an eMachines W4022, is version of the ECS 945G-M3.
IF, my information IS correct, this is ECS Support, and the download page for the Motherboard Manual, for the ECS 945G-M3 motherboard,
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=527&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Go down to the heading - Download.
To the right you will see - Taiwan, USA, Europe, and China.
These are the download server links.
You Left-click on the country name, that is nearest your country you are in.
(I have always found China to be the best for me, and I am in the USA)
After you click on the download server link name, a small window will come up on the right.
My advice is to Left-click on the circle to the left of - Save File.
(This will save the file to your computer. Then you can look at it anytime you want, and won't have to download it again)
Now go to the bottom of the window, and click on OK.
This is a Zip file. A Zip file is used to compress information, so it can be sent over the internet easier. You have to unzip the file.
If you do Not, have your downloads set to go to your My Documents folder, (Windows XP. Documents for Vista), this will go to your desktop screen.
(Windows XP: Left-click on Start, then click on My Documents. In the My Documents folder, this file may have gone to another folder. Folder name is Downloads. Double-click on it to open it)
The file will have 945G-M3 next to it.
When you see the file name, Double-click on it. This will open the Unzip Wizard. Go to the top left of the page, and left-click on -
Extract All Files.
Left-click on Next, Next, and Finish.
You will now see 945G-M3 (1.0b) next to an Adobe PDF icon.
Double-click right on this file name.
You are now looking at the Motherboard Manual.
The connector on the motherboard you are looking for is the Front Panel Header. (Connector on a motherboard is a header) Also known as PANEL1.
Go to Page 20. (Page 12 on the document)
Looking at the top of the PDF file you will see a blue Down Arrow. Click on it to go to Page 20.
The small white squares represent the pins on the connector. The black rectangles shown that go from pin to pin, represent the connector on the wires.
If somehow you cannot download the PDF Motherboard Manual, or are having trouble understanding the Front Panel Header connections, allow me to explain where the wires go.
Let's orient the motherboard position so that we are both looking at it the same way. Same direction.
Processor at the top. Ram Memory slots to the right.
The PANEL1 header is down on the very bottom Right.
The header is rectangular in shape. It has Green, Red, Yellow, and Blue areas on it.
There are two rows of pins.
4 across the top.
5 across the bottom.
The pins are numbered.
Starting at the Top Left, and going across to the Right;
Pins 2, 4, 6, and 8. (There is No Pin 10. Just an empty spot)
Starting at the Bottom Left, going across to the Right;
Pins 1, 3, 5, 7, and 9
1) Pins 6 and 8, are for the Power On switch. (Switch is behind your Power On button)
2) Pins 2 and 4 are for the Power On light.
3) Pins 1 and 3 are for the Harddrive activity light. (HDD on the wire connector)
4) Pins 5 and 7 are for the Reset switch, (Behind the Reset button)
5) Pin 9 is Not used. Nothing connects here.
Would appreciate hearing how this comes out.
Regards joecoolvette
SOURCE: restore factory settings
Do you have the windows install disc.If so place it in your cd or dvd drive.Reboot pc.
Follow on screen instructions for reinstalling windows being sure to format your hard drive.You will loose everything.
Try a trial version of panda antivirus first, run a full scan.
Note.. some e machines are not sold with a disc,there is a system restore option on some e machines.
SOURCE: I JUST WANT TO RESTORE
Hi ,
Please follow the steps required for restore you system factory setting.
1. Click on Start and then All Programs
2. Click on the eMachines folder
3. Double click on eMachines Recovery Management.
4. It will open your recovery console.
5. In Recovery management console you have different option .( Left side menu)
6. Click on Restore. It will open the three options.
Completely Restore System to Factory Defaults - Restores the computer the factory settings, all data on the computer is removed and cannot be recovered.
Restore Operating System and Retain User Data - Restores the Operating System on the computer, files within the User accounts folders are moved to "c:\backup".
Reinstall Drivers and Applications - Launches the application used to reinstall the drivers and applications on the computer.
Which option you want to use ,click on that and follow the instruction.
Hope this will help you.
Thanks for using FixYa.
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
