Naxa Electronics NX-671 Car CD/ MP3 Player Logo
Posted on Jan 17, 2009
How to set the clock on the car stereo (Naxa nx-670)
Bought used car with Naxa nx-670. The manual doesn't have instructions for setting the clock. I have tried holding several buttons in with radio on and with radio off. I haven't found the right combination. Help!
  • 1 more comment
  • Anonymous May 10, 2009
    I purchased the exact stereo and I too can not seem to figure out how to set clock. Please assist?
  • Anonymous Mar 23, 2014
    how do I set the time on my car stereo it's a Naxa
  • Anonymous Mar 26, 2014
    i dont know where anything goes
Anonymous
Level 1:
  • Contributor 7 Answers
  • Posted on Mar 10, 2009
Anonymous
Contributor
Level 1:
Answers
7
Questions
0
Helped
3713
Points
37
I had the same issue. I bought my 671 mp3 car stereo from jujudeals.com and I was having the same problem. I called them up and they said that I have to go to clock mode. When in 'Clock Mode' you have to press and hold Select (SEL) and at the same time press FF/REV to adjust time. (Fast Forward adjusts hour, Rewind adjusts minute). If your still having problems contact the Naxa Electronics warranty department. Goodluck!
  • mrbojangles8 Jul 13, 2011
    This is great, but how do get it in "clock mode"???
    oh, and how do you pre-set radio stations? (This is also not covered in the manual)
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1794
Points
5
On the NX-670,,I was just playing w/ the buttons & found out how to set the clock.On the right side press & hold the blue select(sel)button,while still holding sel down,press the reverse for hours(am or pm will be displayed),for minutes,use the fast forward,or next song button,,worked for me.
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
I LOST THE CHARGER/RECTIFYER. hOW CAN I GET A REPLACEMENT? AND A COPY OF THE MANUAL. BY THE WAY, MAY SAMPLE IS NX-381, NOT 382 BUT THE NEAREST FOUND IN YOUR LIST WAS NX-382
This should be the link to a manual for your player. Naxa Nx-382 manual. For a charger/power supply you can try an generic one from walmart or off the net. They come with different ends to fit many different devices, and have variable voltage settings also. See this one from iGo. iGo wall charger.
9helpful
2answers
I HAVE A NAXA NX-671 AND CAN'T FIGURE OUT HOW TO SET THE CLOCK
I got a 671 from jujudeals.com and the exact same thing happened. When I talked to them, they said to first, go into clock mode. While you're in clock mode, press and hold select (SEL). Still holding select, use the Fast Forward and Reverse buttons to change the time. FF will change the hour, REV will change the minute. Hope that helps, and if not, you can contact the Naxa support people at this page:
http://www.naxa.com/newsite/support.html
1helpful
I just installed my Naxa NX-670, and now when I attach the faceplate, nothing works.
If you run into this problem, be sure that all the fuses to the wiring leading from the battery to the radio are good, then be sure that the yellow wire is attached to the constant power source and the red wire is attached to the acc/ignition power source.
3helpful
2answers
How do i put movies on the NAXA NX-142?
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses.
Good Luck
1helpful
Changing the theme on the Naxa NX-142
go to your local audio store they should be able to order you one or google what you need.
Could someone please give me a simple (I'm auto mechanically challenged) step by step instruction on how to install a new radio in my Ford Windstar. It is a 1996 and the stero I am putting in is a Naxa NX...
Typaclly if you purchased the faceplate install kit, and harness kit, the install will be very easy. You will also get a set of instructions for each kit.
The first hurtle you will have to leap will be removing the old radio, this requires a set of removal tools that fit into the four holes in the face plate of the stock radio. This set may include 2 to 4 tools to put into the holes to unlock the unit, once you have it out, install your harness kit, faceplate and stereo.
Hope this is of some help.
Ed
Naxa NX-670 DETACHABLE STEREO AM/FM.MPX CAR RADIO WITH COMPACT DISC PLAYER And AUX-IN JACK what is the wattage of this stereo
The manf claims hi power which usually means 50 X 4. More likely the actual power is more like 8 to 10 watts X 4.
3answers
How to charge battery
I think it recharges by taking some power from the computer when it is connected. I also use a cell phone charger from the razor series of phone.
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
