Can't initialize @ start up lights strob and display reads c 1?
Hp officejet 7110 when powering up, all lights strobbing and display has several symbols with c 1 at the end. Machine is completely locked up - any hope? THANKS!
Hi...I have the same problem. There is no grinding noise but it the lights are strobbing and it won't let you do anything. Hi...I have the same problem. There is no grinding noise but it the lights are strobbing and it won't let you do anything.
(sorry for my english)yes, i have the same problem
display reads turn power off and on
i tried push #3, #6 and #9 but no solution.
You can't post conmments that contain an email address.
Do you get the same effect if you play a DVD through your set? If not, then the problem is perhaps with your aerial or your receiver if it is separate from your TV.
you have to check for a loose contact at the main board then you can check the flyback transformer which have leak. the the high voltage is arching at the picture tube.
If you don't have a copy of the ISS4000 user's manual, please use this link to download a PDF version of the manual: http://www.intova.net/support/intova-manuals/. If you need to talk one on one with us, please call Intova directly at 877-837-0074 (US only) or 808-837-0074 or email us at [email protected] and we can help you. Thank you, Intova
Connect the printer to the system and power on the printer. Start the system let it boot completely, put the CD that came with the Printer and install the drivers . From the same CD, run the setup to install the scanner software for the printer. Read cafefully the instruction on each installation wizard window that opens and follow the instructions.
However, if you are using windows 7 Operating system, just install the printer driver, go to start, All Program, Windows Scan and Fax. Lunch this and with it you can scan your document
it might be a hardware issue with the printer however we still can try the following stes to reset the printer.
1 Take out the cartridges from the unit . 2 Make sure the unit is connected to the wall jack directly without any surge protector. 3 Unplug the power cord from the back of the unit ( without turning off the unit ) . 4 Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit . 5 Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off. 6 after one minute turn on the prnter . it will go into alligment phase > let it finish . 7 after its done > try to make a copy
