Air Conditioning and Heat for Mercedes-Benz ML350 Logo
Clarence Posted on Dec 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to take out heat fuse - Air Conditioning and Heat for Mercedes-Benz ML350
Christian Krentz
Level 3:
  • Mercedes-Benz Master 694 Answers
  • Posted on Mar 02, 2014
Christian Krentz
Level 3:
Answers
694
Questions
Helped
159985
Points
1404
Check your owners manual for a fuse guide
Samsung dryer model #DV328AERXAA. We replaced: 4 drum wheels, belt, light, heat coil, heat thermostat & fuse, thermister & fuse, and the control panel still no heat? starts then heat coil fuse blows
on the main controller board there should be some micro switches these a relay type and were out or get overheated, but if this is on gas. it can be the flame sensor https://youtu.be/VTnDslKW6y0 electric.
https://youtu.be/7KaMwV85qUI Gas
My kenmore 110.64832400 won't heat up
if it wont heat up most likely it had a open in the heating element.it will need to be replaced but before that check the little plastic thermal fuse that is on the front of the exhaust fan housing.an easy way to see if the fuse is bad is to just bypass the fuse by hooking the two wires that go to the fuse together and running the dryer. if the dryer heats up when you bypass the fuse then replace the fuse.if it does not heat with the fuse bypassed then replace the heater coil
2answers
How to repair a drivers heated seat on a 2007 Ford 500
The following checks and repairs can help you:
1. In the fuse box within the bonnet - check fuse number 22, if burnt, replace it
2. Check fuse 19 in the fuse box inside the car located under the dashboard on the driverside
3. If these steps don't help, the problem may be with the wiring and connection between the module and the seat cushion - inspect it
4. Check if the signal return on the circuit is adequately functioning - if the module is being informed of an active seat
5. If there is a problem - repair or replace the circuit and/or wiring.
2helpful
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 • Dryers
2helpful
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
2answers
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Fuse location
There is not a fuse listed for heated seats but fuse 16 is for heated mirrors and fuse 11 is power seats. i'm guessing one of those should also control the heated seats.
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
