HeTer want come on Nd condenser want turn off.
SOURCE: wiring daigram
Go to "truemfg.com". You can fill in your info on the home page and gain access to a 24 hour, on-line tech support. Worth a try.
SOURCE: convert freezer to refrigerator
Converting a freezer to run like a fridg can be done ,however it is sometimes tricky. you have to replace the thermostat, you will also want to shorten the defrost time setting. and may have to disable the fan delay to let the evaporator fans run all of the time, to prevent short cycling of the compressor.
SOURCE: I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
SOURCE: I NEED A wiring DIAGRAM FOR a T-72 F TRUE FREEZER
Because I am not sure of your location in this world I will leave you with their home page. The Home page can take to any place near your location. Sea Breeze
SOURCE: I would like to have a wiring diagram for a model 6125 freezer
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
Start with this web site. It has Delfield old manuals. Page 6 has wiring diagrams.
Hope this gets it for you.
