Kalorik Jk-19967 1500 Watt Cordless Jug Kettle White Logo
How do I replace the filter on the Kalorik Cordless Jug Kettle?
When emptying the water from my kettle the filter also came out into the sink. I don't recall where it is supposed to go. How do I put it back where it belongs?
1 Related Answer
Anonymous
  • 3006 Answers
  • Posted on Jul 26, 2009
SOURCE: I have a kettle which has now broke. Have reciept
Contact Swan using the details on the warranty card.
I need a spout filter, part # 31036 for my express kettle MEK 17W
  1. New: Melitta Kettle Parts - buycheapr.com‎
    Admelitta-kettle-parts.buycheapr.com/‎Melitta coffee maker parts: BuyCheapr.com
  2. Melitta Kettle Parts - bizrate.com‎
    Adwww.bizrate.com/Melitta+Kettle+Parts‎Vacuums
  3. Microwave Ovens
  4. Coffee Makers
  5. Heaters
  6. Melitta Cordless Kettle - Amazon.com‎
    Adwww.amazon.com/kitchen‎rating for amazon.com
    Up to 50% off Melitta cordless kettle Free Shipping on Qualified Orders.
    Ratings:Website 10/10 - Shipping 10/10 - Selection 10/10
Search Results
    Need replacement filter for Melitta Express Cordless Kettle ...
    www.fixya.com/support/t6685355-need_replacement_filter_melitta
    Nov 3, 2010 - Need replacement filter for Melitta Express Cordless Kettle Model MEK17W - Salton Melitta MEK17W Electric Kettle question. ... Question about SaltonMelitta MEK17W Electric Kettle ... Video; Photos; Link; Replacement Parts.
Bulb in Ikon kettle no longer lights up
I had this problem recently; I think my kettle have accidentally been turned on empty. The kettle has a safety for that, described as follows in the manual:
"The kettle is fitted with a safety device, which protects against overheating should the appliance be operated with insufficient water. If this occurs the kettle will stop heating. Switch 'Off' at the power
point and allow kettle to cool before refilling. The safety device will automatically reset when the kettle has cooled down."
Then they go on to tell you that there is an additional thermal cut-out, and if that is tripped, you have to send it back to Breville for servicing. However, it might not be that bad-- it wasn't in my case.
The heating connector and control is made by Otter, here's information that I was able to find about it on their website (Otter A1 and CS7 control and connector-- I think the kettle actually uses a CS4 connector, but the thermal cut out isn't described on that data sheet):
"The A1 control integrates to 360° cordless plug with element
dry boil protection. Two bimetals spring loaded against the
element surface make a fast response during dry boil. One
bimetal disconnects the live side of the electric circuit and the
other disconnects the neutral. A latch out function prevents
dry boil cycling. This automatically resets when the kettle or
jug is lifted from the cordless base."
http://www.ottercontrols.co.uk/support-downloads/domestic-data-sheets
So what does this mean to you? If you look at the bottom of the kettle jug, there is a circular indentation that slots into the base. There are two white plastic things which I believe are part of the "latch out" described above in Otter's documentation. If you see them sticking out, they may be stuck in position instead of resetting as they should. Use something like a pencil eraser to gently poke them so they unstick, then put the jug back on the base. That should cause them to retract, and at that point your kettle should work again.
3helpful
2answers
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
1helpful
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
2answers
Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
3answers
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Top Kalorik Kitchen Appliances - Others Experts
john h
Are you a Kalorik Kitchen Appliances - Other Expert? Answer questions, earn points and help others
