Screen display is all messed up as in coulours arent what there supposed to be have reset to factory settings and problem is still the same
SOURCE: where to buy lcd screen for archos 80 g9
not sure you want to do that you can google it, it does come up with places that sell it. problem is they dont always work you may have to buy 2 they will charge you to fix it if it is out of warantee aprox 25% of the value of the device or just shiping if still under warantee but LCD/LED is not coverd by warantee if you can convince them that the display malfunction is something other than the LCD/LED they will replace a waranteed one for shipping charges alone no questions asked but you have to convince them it is some thing other than the phisical display its self wich should not be too dificult they are pretty durable and can still display a fairly good image even when cracked in multiple places often the touch screen will also still work when cracked too not very many tablets can say that :) hope that helps
SOURCE: Hi, my Archos 80 g9 display screen is broken, can i buy new display from you?
the display screens can be purchased but good luck finding some one to install it just google it and buy 2 because often some of them dont work from the factory ooorrr you can have archos fix it wich may be cheaper and easyer about 25% of original cost and they will test it and make sure it works before sending it back or send you a new one the screen problem is not specific to archos its specific to that type of screen they have a half life of about 5 years but may die sooner under constant use or abuse and some die as soon as they are powered having archos replace it prevents you from having to buy multiple of them to find a good one samsung also uses the same type of screen but does not use the laminating or layering proces that archos uses to increase the durability and third party screens also dont have this eather so having archos do it will also ensure you get a laminated and layered set up that will last you a bit longer than one you might purchase after market and have some one put in for you
