could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
When you can't find what is wrong, the battery, the connector in the tablet, the cabling (in the tablet or from the charger) or the charger, you should ask a tech person, if he / she can find what is wrong. Most phone repair shops can find what is wrong if you take everything there. Before you leave anything there for any repair, first ask what they will charge you EXACT.
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge. If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol. I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
