Which battery do i need
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
SOURCE: describe how to use the self timer
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
SOURCE: How do I format a new sd card on my samsung s830
Just go into the menu and find "format"...follow the on-screen instructions.
