Yes, What you said was absolutely right. It has the hanging problem whenever one plays the video or tries to use the camera.
But there is a good news for you friend!.
I tried to update the software and successfully updated. I too was facing the hanging problem. Whenever I use the camera or the media player to play the videos the phone was hanging a lot. I was facing exactly the same problem just like yours. So don't you worry! You can feel easy now!
Now after the software updatation, the problem got solved. Now the latest software update version V 07.20 is available. If any one is facing the similar problem of phone getting hanged, you can update the software using the gprs service.
Nokia PC suite has also got updated. Now the latest version 3.0.0.284 is available. Those who use the Pc suite for browsing the internet using the nokia phones can update the pc suite.
The hanging problem might be as a result of the follow:
Maybe there is a virus on your phone.
Maybe the phone memory is full.
Memory card also might be full or maybe the memory card has virus
Your phone operating system might me corrupt.
Solution(s):
Try to delete the files on the phone memory and let's see what happens
Remove the memory card and put on the phone without it and see if the phone will still hang
Master reset the phone and see if phone will still hang
If you try all the above and your phone still hangs, then you will have no choice than to take your phone to a qualified phone repair shop for software restore. That is, computer will be used to format your phone and the phone software will be reinstalled afresh to its factory default state and you will not see any trace of hanging on your phone any more.
very common problem with w910i. back up your numbers and photos, and then try a master reset on phone. if still hanging, the phone will need a full format and software upgrade from an authorised sony ericcson service centre
1.backup first all of your contacts and important files 2.make a master clear w/ your phone and after restart. 3.if still the same make a fullflash or upgrade your firmware.
jha - you could be having a problem with the memory card, you could try a new m2 card and see if it hangs if it does not it was the card but if it still hangs with a new card then you should try and reflash the firmware on the phone.....to fix it...you can do this online at topsony.com or at a mobile service center.
select your country or region. then select the phone model number, which is 6610 in your case...that page will have the pc suite...which you can download and install on your pc, using which you can install or upgrade the software on your mobile. :)
My mobile is more times hanging.
I need solution.
