Question about Canon PowerShot SX500 IS Digital Camera - Jap/Eng
Reading memory card error
I'm trying to take pictures and it is beeping and reading memory card error
SOURCE:
SOURCE: Memory card error
This repair is covered by a mass recall by Canon. See their website for details. No charge for out of warranty
Posted on Mar 14, 2007
  • 36 Answers
SOURCE: Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
Posted on Dec 28, 2007
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
Posted on Mar 31, 2008
SOURCE: Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Posted on Jan 12, 2009
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
What is memory stick error C:13:1
It is caused by the camera not reading the memory card properly. Try removing the memory card, then insert it again, wiggle it a bit. Of it still won't work, try cleaning the gold parts of the memory stick, using an ordinary pencil eraser.
Sep 18, 2011 | Sony Cameras
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
My pny optima sd memory card is reading card error after i used it for 1 day. now i can't get any pictures out of it.
faulty i'm afraid, try the manufacturer for resources to get the data if any?!? good luck
Apr 06, 2010 | PNY 2GB microSD Memory Card
SD 215mb memory card reads ''memory card error''
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 12, 2008 | Vivitar ViviCam 5385 Digital Camera
Camera not reading SD card after being removed from my reader
Put the SD card back into the card reader. Are you files still there when the computer tries to read them?
If they are not, then it is very likely the card is corrupt. This happens when the card is removed before the computer is done reading/writing to the card.
There is also a SLIM chance the card is just bad.
Nov 06, 2008 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Aug 04, 2008 | Cameras
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Canon PowerShot SX500 IS Digital Camera - Jap/Eng Logo
225 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
