How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
Turn your tablet off and remove the SD card, if there is one.
Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
if you have a google account, you can do this option
When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
Now provide your Google account username and password attached with your device and click on "sign in".
After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
Power off your phone.
Now press Volume up, power and home button at the same time and wait until your device starts.
When you see logo screen release the power button and keep pressed the other two buttons.
Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
Now it asks you for confirmation, select "yes".
After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
If you configured a Google account on your tablet, there is a Forgot Pattern option available if you enter the incorrect pattern 5 times. For a clearer answer, you should repost with the make and model of the tablet.
this is an easy fix, 1. with the tablet off, press the power and vol up buttons together until unit comes on.2. using the volume buttons select wipe data/factory reset and use power button to comfire. once tablet restarts it will be just like new out the box. hope this helps
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
Please reply if it helped
