Hello, My names Dave and I can tell you that you all most likely have a bad Z sustain or Y sustain board! The good news is that most of the time if either of these boards are bad you will find a blown fuss one them! I have worked on this same model of TV many times! You can lay the TV face down very gently and remove the back cover from the TV and test the fuses on the Z & Y sustain boards to confirm which one of the two are bad!
Z sustain board! P/N's:
6871QZH956A or
6871QZH056B Here is a link to the Z sustain with a picture of the board so you'll know what you're looking for
http://www.shopjimmy.com/lg-6871qzh056b-zsus.htm If you look at the Z sustain board you'll see that there are two white fuses on the board FS1 & FS2 are the location #'s. There is also a third fuse (FS3) it is a surface mount type fuse and can be easily over looked. Just locate the 8 pin main plug right next to the other two fuses and you can't miss it. It's smaller and it will have
gold colored ends on it and it to is white with the location # FS3 next to it!! If any of these fuses are blown you will need to replace the board to complete the repair! You will need to test the fuses for continuity with a DMM (
Digital Multimeter) Do to the fact that you will not be able to just look at the fuses and be able to tell if they are good or bad!
You'll also want to test the three fuses (
FS1, FS2, FS3) on the Y sustain board P/N's:
6871QYH953A 6870QYH005B
! Here's a link to a picture of this board also.
http://www.shopjimmy.com/catalog/product/view/id/179043/s/ysus-6871qyh953a/Two of the fuses (FS2 & FS3) on the Y sustain are easy to find because they are normal white fast acting type fuses! The
third fuse is also a surface mount type fuse and can be easily over looked. Just locate the 9 pin main plug right next to the other two fuses and you can't miss it. It's smaller and it will have gold colored ends on it and it to is white with the location # FS1 next to it!
If any of these fuses are blown you'll need to replace the board to complete the repair! You will need to test the fuses for continuity with a DMM (Digital Multimeter) Do to the fact that you will not be able to just look at the fuses and be able to tell if they are good or bad!
If you have any questions please feel free to contact me via
www.pleasefixitdave.com there you will find all my contact info!
Dave~
