If you mean you want to access the internet through your mobile data plan, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access point names', and make sure your carrier's data plan name is shown there. If so, tap over it and change the data, mainly 'APN', 'Username' and 'Passowrd', according to your carrier's instructions. Otherwise, i.e. if there is no data plan shown at all, tap 'Menu > New APN', and fill in the required data. In both cases, after you finish, press 'Menu > Save'. Then, press the back button as many times as required to take you where you were, before you started changing these settings.
On the other hand, if your intention is to access the internet through your phone's Wi-Fi card, go to 'Menu > Settings > Wireless & networks > Wi-Fi settings', and, if the 'Wi-Fi' checkbox is unticked, tick it. After a little while, a list of available networks will be shown. If you want to refresh that list, tap 'Menu > Scan'. Anyway, if the network you want to connect to is in the list, tap over it and tap 'Connect'. You will be prompted to fill in the passphrase (if any). Otherwise, i.e. your network is not shown (e.g. it is hidden), tap 'Add Wi-Fi network', fill in its name, under 'Network SSID', the security encryption method, and the password (if any). Then, tap 'Save'. You can also specify your Wi-Fi sleep policy and other settings, by tapping 'Menu > Advanced'. After you finish, tap 'Menu > Save'. Again, press the back button as many times you need to go back to where you were before.
By the way, if your phone's user guide happens to be missing, feel free to download it from
this location.
Anyway, please, let me know if I can help you out any further.
Regards,
Carlos
