Easy test to determine problem. Plug compressor directly into outlet without extension cord. Start compressor with no air in the tank. It it starts, fill to 50-60 psi and unplug from wall to stop. Wait few minutes and plug the compressor back in. It it starts, most likely problem is too heavy oil or the use of extension cord. If it does not start after few minutes wait, most likely not unloading due to leaking intank check valve or bad cold start valve (see reference # 47 on your parts list). The cold start valve should release air from discharge tube after few minutes. If the intank checkvalve is leaking, the cold start valve will not work and stall the compressor. If all test ok, then just replace oil with 10 - 15 - or 20 wt. Good luck
