Just installed Tub model 7236LC and everything turns on and works but I hear a faint beeping sound from motor. I haven't enclosed it in entirely so Im not sure I would hear it once I'm finished. All gfi's work properly and everything is grounded properly so I'm not sure if the motor makes that sound or sound thing wrong.
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
SOURCE: I bought American Standard whirlpool
no manual. Sounds like the motor is no good. What model and brand of pump do you have?
replacement Bath Pumps
SOURCE: american standard air tub motor hums
That motor solution is correct. I called the company American Standard and fortunetly, mine was still under warranty. They sent out a plumber within 3 days to replace the motor and now I'm back in Kansas Dorothy.
SOURCE: Button on American Standard Whirlpool tub is stuck
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
SOURCE: My American Standard Whirlpool does not turn on.
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Replacement Air Switch will cost you about $20
US Parts Center
