Microwave Ovens Logo
Steve Gih Posted on Dec 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not heating efficiently; works but doesn;t heat as well
David Low
Level 3:
  • Master 458 Answers
  • Posted on Dec 27, 2012
David Low
Master
Level 3:
Answers
458
Questions
Helped
138903
Points
1304
If it is taking longer to heat things than normal then it would appear the Magnetron to starting to wear out, this is a normal sign of inefficient power from the magnetron & would need to be replaced.
1helpful
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
1helpful
Maytag microwave problem everything seemingly works but does not heat. Help
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Oven is not making etables heat
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Microwave runs but doesn't heat
HI>An oven is equipped with a heating filament that is called.Magnetron.Now if the motor is working but the unit is not heating .Then MAGNETRON is defective and must be replace.
It works normal but doesn't heat.its 11 yrs. Old. Do I repair or replace it.
It would be much easier, and cost efficient to replace the Microwave, especially if no heat is being generated.
If the light, or turntable went out or something, maybe then a repair would be more reasonable.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
1helpful
2answers
MY MICROWAVE DOEST HEAT, IT LOOKS LIKE WORK NORMALY BUT DOESN HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
Microwave oven trouble
Obviously, heat escaping from anything heated in the oven will indirectly heat the walls and the magnetron is not 100% efficient so it radiates a good deal of heat but that is normally carried off by the cooling fan and exhausted into the room air.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
