SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
SOURCE: kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
