We had no power failure that i am aware of, all the other phones in the office seem fine (and are different models), but every button on the phone at the reception desk rings to the same extension, including the hold button, release, feature- everything!
SOURCE: Norstar M7310 Phone's Buttons Don't Work At All
What system is this on? Sounds like the system is going downhill.
SOURCE: Any button pressed on admin phone calls another phone's v.m.
Sounds like one of the speed dial buttons is stuck down on that phone
SOURCE: Every button including feature Meridian 7310 calls to an internal
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
SOURCE: Incoming calls sound only on reception desk.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
SOURCE: All buttons dial the same line.
Check to see if the one touch button for the cash office is stuck down, sometimes the corner will stick but is hard to notice its down.
