Question about Ranger Radio Communications
Audio in my rci 2970 has no punch to the audio
    Genius:
  • Ranger Master
  • 1,847 Answers
Cut back on the power,turn up the modulation and you should be good.
Posted on Feb 23, 2015
3 Suggested Answers
SOURCE:
  • 16 Answers
SOURCE: RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at (noteethontop@yahoo.com). put 2970 in the subject line. Take care.
Posted on Jan 19, 2009
anymhz
  • 500 Answers
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
How to change a memory battery in an RCI 2970
its the round dime sized battery on the back of the cpu inside (back of faceplate) there is an battery upgrade. www.cbtricks.com
Feb 10, 2014 | Ranger Communications RCI-6900F-25 CB...
Rci 2970 blown fuse
open the fuse holder in the back of the radio get the number off it. It will probably be a 5 amp fuse but whatever ,replace it with the same one.
Apr 05, 2013 | Ranger Radio Communications
My Ecoquest Fresh Air purifier display reads: NEEDS RCI CELL. I have ordered one online, is it safe to run the unit until I receive and replace the rci? I can already tell a difference in allergy symptoms...
By all means run the unit while you wait for the new RCI cell. The purifier will be less effective in killing germs while the RCI cell is out. It will still work to reduce the allergens in the air. Hope this helps you.
Feb 04, 2011 | Ecoquest Fresh Air Air Purifier
I HAVE A SADELTA BASE MIC NEW MODEL ON MY RANGER RCI 2995DX, I HAVE BEEN TOLD THIS MIC COULD DAMAGE THE RADIO,COULD YOU TELL ME IF THIS RIGHT. BACAUSE I AM HAVING GOOD REPORTS WHEN IAM TRANSMITING. THANK...
those mics are supposed to work for most radios ,,,if your getting good audio reports,,i wouldnt worry about it ,,im thinking of getting one for my icom 735 radio,,how much did u pay and where did u get it,,,,if you are worried about damaging your radio,,get a hold of ranger ,,and ask them about the mic
trevor berg
Dec 07, 2010 | Ranger RCI-2995DX Base Scanner
Need operating instructions for RCI-6300F150
You can download and print the operating manual for your 10-meter transceiver here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_om.pdf
In case you need it, you can also download and print the service manual here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_sm.pdf
Bill B.
Oct 25, 2010 | Ranger RCI-6300F-150 Base Scanner
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
Nov 26, 2009 | Radio Communications
RCI 2970
May 06, 2009 | Ranger RCI-6900F-150 CB Radio
Jan 17, 2009 | Radio Communications
Radio Communications Logo
117 people viewed this question
Top Ranger Radio Communications Experts
Steve Allison
Steve Allison
Mike Charette
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
