Computers & Internet Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OSD lock out
I am trying to restore the volume in my computer and right now the screen display says OSD lock out. Can you help me unlock the on screen display?
  • Anonymous Jan 28, 2009
    can not access the function buttons / osd lock out. tried the 3 solutions and they do not work
  • Anonymous Mar 29, 2014
    My screen is dark when I look close I can see it saying osd is lock what can I do
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1805
Points
7
Try holding down the Select and the Function Keys at the same time
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Jan 16, 2009
Anonymous
Expert
Level 2:
Answers
98
Questions
0
Helped
56468
Points
320
Push one of the monitor buttons and hold it for 5-6 seconds. I'm not sure which one it is on NECs.
Hope it helps.
Anonymous
Level 2:
  • Expert 258 Answers
Anonymous
Expert
Level 2:
Answers
258
Questions
0
Helped
138802
Points
619
Try Pressing the Auto button on the monitor below the screen.
If it doesn't have this press the right or left arrow until you find "Auto" or "Auto Adjustment" then press the menu or selection key to the left, this should reset it
1helpful
My computer says OSD locked , ive tryied every thing and nothing worked , HELP!!!!!!!!!! PLEASE
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
7helpful
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
32helpful
2answers
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
19helpful
3answers
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
2helpful
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
13helpful
2answers
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
1helpful
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
2helpful
2answers
On screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Top NEC-Mitsubishi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
