The fuse box is mounted under the dash on the left SIDE of steering column above the dead pedal / foot rest. Black box 2" X 3", pop the cover off and there they are
If you are suspecting that the radio, car lighter fuse is busted. You need to check the fuse box under the dashboard. Check the fuse box diagram found on the cover of the fuse box under that dash. Check if you see "Lighter, Radio" Find the fuse and use the fuse puller to pull out the fuse.
You can find the fuse puller inside the fuse box. I hope this helps.
if it the old vitara i had exactly the same problem i shorted the fuze when trying to fix the windows and i could not find the fuze. By trial and error i found that the fuse is the round one next to the fuze box inside the car. Hope this helps.
TRS LP TRS 3/4 TRS 2/TCC These are the fuses for the solenoids in the valve body Inside the Transmission, they turn on & off as needed to shift. Check all of those fuses, making sure they are not corroded or tarnished. Make sure that your charging system is functioning properly.
HI,, OK to open the bonnet or hood on a suzuki vitara.
Go on the passanger side open the glow box, in the uppper right corner you will see the knob to open the hood.
thanks your a star
