How do I change the SSID & Password on this wireless router. Why is it that I can access my web service with my tablet pc without having to give my router's SSID & Password & my grand kids can't? Will changing the Belking SSID & Password & giving it to the kids, allow all of us to access the web?? Thanks--Rick L.
SOURCE: Wireless Router RG54G2
assuming you have tried without typing a password; try admin or password or router admin. You can reset the router by a hole recess normally at the rear of the unit using a pen tip and push it in for 5 seconds or so.
SOURCE: Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: My wireless name (SSID) and security settings keep changing on their own!
hi,
well i saw the problem u r facing
and the only soution for it is the upgradation of the firmware ....
i was facing the same one on my router and it got corrected ....
otherwise u can call the customer care no of the the routers company and they will give u the replacement
SOURCE: cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
SOURCE: Change of current belkin N150 password.
from the control panel update firmware to latest http://en-us-support.belkin.com/app/answers/detail/a_id/526/kw/n150/r_id/166
There ware a bug similar to this in the previous firmware version. Let me know if it works. Cheers...
Hi
1. Connected a computer to the router using a Ethernet cable.
2. Open up a internet explorer.
3. Click on CTRL & O [The letter O as in oscar]
4. In the Open box that appears the top left corner of the internet explorer type the numbers : 192.168.2.1 & press OK.
5. This will take you to belkin router setup screen.
6. Click on Channnel & SSID under wireless on the left side of this screen.
7. Once it prompts to type the password just leave the password box blank & press submit.
8. Change only the SSID to different name to what ever you wish like in last name & press apply changes. [do not change any thing else in this screen]
9. Click on Security under wireless in the left hand side.
10. Choose the security mode to WPA-WPA2 personal PSK & in the pre-shared key make up the password to what ever you wish & then press apply changes.
11. Now try to connect to the wireless network using the new SSID [network name] & the new password that this the security key that you set up in key one.
Thanks
Hi
For local only in Vista computer.
10. Change the security mode to 64bit WEP.
11. In Key 1 make up a password for your wireless all numbers. It takes 2 digit numbers in each box & press apply changes.
12. Now try to connect to the wireless network using the new SSID [network name] & the new password that this the security key that you set up in key one.
Thanks
