I have connected the printer with a usb/parallel cable to port USB001.
Initially it works fine but after some time of not using it it does not work anymore.
The printjob comes in an error state.
If I disconnect/connect the USB cable, it start to works again.
The USB connection is direct to the USB connector of the PC, not using the hub.
Any ideas?
Thank you.
Thank you very much for the quick reply.I tried it but I got a better suggestion from another forum: Use the USB connection of the printer instead.
I did not even konw that there it is possible to use a direct USB connection.
Thanks again.
