Whirlpool GBS307PR Electric Single Oven Logo
Sharyl McKenzie Posted on Jun 19, 2007
The F5 error code?
Whirlpool Super Capacity 465. The self-cleaning oven has worked fine up until last week. There oven was here when I moved in, so I don't have a troubleshooting book. Anyway, when I place the self-cleaning oven on, it will heat up for about 30 minutes and then the F5 error comes on. The oven will not open, unless I unplug the oven. Does anyone know what the F5 error message means? Or, better yet, how to fix this problem? Any help would be greatly appreciated. My oven is dirty. :) Sharyl
  • 3 more comments
  • wisguyz5 Nov 24, 2007
    recently purchased a home, noticed front door on my oven will not open and there is an F-5 code (error) on the l.e.d. screen....whirlpool oven, don't know the model or s/n......any and all suggestions are appreciated...
    thanks
    shane
  • Anonymous Apr 22, 2008
    My husband started the self cleaning oven cycle and when he thought it was finished - the oven door remained locked. The F5 error code came up but there is no book. I do not know a model number.. I just want the thing to stop beeping and work. Thanks, Fritz in 29 Palms
  • Anonymous Oct 09, 2008
    F5 error started while self-cleaning. Door won't open - light on. Probably Whirlpool RS696PXG. Unplugged for hours - did not fix. How do get inside to check things? Thanks. Richard
  • rgbruno Oct 09, 2008
    F5 error started while self-cleaning. Door won't open - light on. Turned off breaker for hours - did not fix. Probably Whirlpool RS696PXG. How do I get inside to check things? Thanks. Richard
  • Megan W
    Megan W May 05, 2017
    According to the Whirlpool oven manual and tech sheet, an F5 E1 is a door lock related error code. Below are the three causes of F5 door lock related errors. Two of them can be expected by looking at the wiring diagram. The third one is totally unexpected and not mentioned in the Tech Sheet error description section (or anyware else that we’re aware of).
    The Symptom and Documented Solution: An F5-E1 error is thrown on the lower oven.
    The Tech Sheet says:
    F5 E1 “Self-clean latch will not lock”
    1. Check the latch assembly: latch arm pivot joint, arm/solenoid connection, solenoid spring, and spring washer.
    2. Check the Latch Solenoid:
    – Check for firm electrical connections.
    – Disconnect the two wires from the solenoid and measure the resistance of
    the solenoid. A small resistance (approx. 175?) is normal. If the solenoid is
    open (??) or shorted (0?), it should be replaced.
    3. Check the Latch Switch. Disconnect it and use a continuity tester:
    – Door latched = switch closed, continuity should read 0?.
    – Door unlatched = switch open, continuity should read??.
    4. Check Door Open/Closed Switch. Disconnect it and use a continuity tester:
    – Door open = switch closed, continuity should read 0?.
    – Door closed = switch open, continuity should read??.
    5. Check power and element connections.
    The Actual F5 E1 Causes
    ONE– Problems with switches in the latch mechanism as mentioned in tech sheet.
    Fix: Repair or replace lock mechanism/switches.
    TWO– Door latch drive or door switch detect failed in control board.
    Fix: We take care of this with our board rebuild process. Call FixYourBoard.com to have your control board refurbished. 512-355-1108
    THREE– Here’s the kicker – this cause is not at all obvious! A FAULTY KEYPAD/TOUCHPAD MEMBRANE!
    How can it be?! Self-clean in the bottom oven of a Whirlpool Double oven is an option. The models that don’t have self-clean in the bottom oven still use the same control board as those that do have the option. A unique combination of shorts in the keypad membrane tell the control board which options are implemented in a particular oven.
    A frequent failure mechanism in the keypad causes the short that indicates “no bottom self-clean model” to fail open circuit – confusing the control board into thinking that there is a lock mechanism on the bottom oven! Now the control board tries to activate the non-existent bottom oven lock mechanism – and throws an error because it doesn’t work (or exist)!
    Fix: Replace the keypad. Call FixYourBoard.com for Ledgestone options.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12124
Points
I unplugged the oven and it cleared the code and was able to self clean the oven.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 19, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
13132
Points
11
Check here, Sharyl: http://www.repairclinic.com/0078.asp#Whirlpool1 F5 Check door/latch switch Replace switch if defective (or) F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel Depending on your model... -j.
1 Related Answer
Anonymous
  • 473 Answers
  • Posted on Nov 03, 2007
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
The F5 error code?
WHIRLPOOL
Code
3answers
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 • Ovens
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
8helpful
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
2helpful
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 • Ovens
Whirpool Super Capacity 465 Self-Cleaning Gas Range error code F5
facing the front of the oven (while off) put your hand along the back of the oven toward the top left side. there should be a techinical spec sheet with a list of what the codes mean and possable solutions.
8helpful
4answers
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 • Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
