Google Android Logo
Mary Sellars Posted on Jun 11, 2017
Wifi wont connect to my tablet
Okay so I'm trying to connect my tablet to the wifi, although the wifi is already set to a laptop and numerous phones, it wont connect to my tablet. The tablet is simply telling me that I am not in range even though I am literally a foot away. I have turned the wifi off and on again I have also unplugged the wifi. The mobile data is on on the tablet as is the wifi. The password is correct as I have re-entered the wifi router onto my tablet a number of times.
4 Related Answers
Anonymous
  • Posted on Jul 24, 2009
SOURCE: I don't have the internet plan on my phone but i do have wifi
wifi is just a wireless connection. u need to connect to an access point that is connected to internet. u can maybe crack nearby WEP keys to "steal some net". anything with WPA encryption would be too hard to crack so just google "cracking wep" and follow the tutorials. do this on a pc with net ofcourse then transfer the program to your pc. good luck.
other than that. pay for a connection.
Anonymous
  • 35 Answers
  • Posted on Feb 01, 2010
SOURCE: locked out of g1
you should have an android back up with google check it out then seek for more help
Anonymous
  • 485 Answers
  • Posted on May 13, 2011
SOURCE: I just bought a zt-180
This error occurs when you do not set up a google account during the initial setup. You can try some of the following steps to see if you can resolve the issue.
-Restart the phone without the SIM card, and connect to some WiFi network, so you can login to your Google Account. It will log you into the account, and then you can put the SIM card back.
or
1. Hard reset your phone. You will lose all information that is currently on your phone when you do this.
Select Settings -> Security -> Factory Data Reset
2. Once the phone reboots, input your google account information when the phone asks for it.
The phone number for android customer support should be 888-486-3987 ,however, I would recommend if you are going to call tech support that you call the provider you purchased the phone from.
Regards,
G33k
johncleme474
John Clemens
  • Posted on Jul 17, 2012
SOURCE: I have just bought a Google Android Tablet 7 inch and we are having trouble connecting WIFI. We've connected a different tablet and my daughters ipod touch with no problems as well as many lap to
the problem I had is when typing passwords etc you have to keep pressing upper case key for each letter,it reverts back to lower case each time.
1helpful
2answers
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
3answers
Why Tablet Wont stay connected to wifi?
this may be because they wifi goes away and comes back again. or maybe because it's messed up .
hope this helps.
Why does my tablet keep saying authentication problem when trying to connect to wifi???
Is this an older tablet by any chance? Some wifi cards on older tablets will not support newer security protocols like WPA-PSK without a software update. An authentication problem can also be caused by mis-typing the key or passphrase for your network, or by having chosen the wrong type of security protocol when asked to join a network. Try deleting the network connection you have already tried, and then rebooting your tablet and let it discover the network again. Make sure you pick the right type of network security protocol for the connection when you try to connect and recheck the key/passphrase after you type it before hitting 'connect'.
Samsung ip adress will not connect
Set up your wifi again but closer to the router.
I just got my kurio 7s last week and now the wifi wont work. the wifi turns on and its picking up my router even says it has perfect signal i hit connect then it keeps going through this 10 min ****...
If you can click on your wifi and pick "forget" do that and then restart the tablet and try again. If that doesn't work try going to settings and resetting it to factory then it will be like a new one, if you can do it without wifi some tablets wont let you past the wifi screen until you sign on.
Wifi issue
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
My d age 988 wont connect to wifi
If it's a Tablet try the Tablet & eReaders category for a Expert in Tablets. All I can suggest is the settings in the tablet. Is the Wireless secured? Is this a recent occurrence? Has it ever connected?
1helpful
I have to place my laptop near the router to get wireless connection
blower your wifi router and push a minny button that is placed on the corner of router
Wifi problems (iPod G1)
i had experienced that problem with my PSP at the same case,just set your internet connection again and delete all of you history,cache and some data in you iPOD.HOPE I HAD HELP
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
