Our Christie DS+60 projector turns off spontaneously after 30 - 90 minutes
We got an error code of b0 one time
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
TIPM (image processor)
60 Boot code CRC failed
61 Unable to program the DigMux PLD
62 Unable to program the Control PLD
63 Unable to program the BUBKS PLD
64 Unrecognized ROM type
65 Write to flash ROM failed
66 General image processor failure
67 Downloaded code will not fit in the ROMs
68 Communication problem with scaler on image processor
BUILT-IN or EEPROM
70 Unable to access the EEPROM on the built-in keypad
71 EEPROM memory re-initialization (built-in keypad)
72 Unable to access the EEPROM on the lamp module
73 Unable to access the EEPROM on the Back End Board
BACK END BOARD
80 Unable to detect Back End Board
81 Unable to program a device on the programming bus
82 TI flash download failure – not started
83 TI flash download failure – partial write
84 TI flash download failure – checksum read
85 TI – I2C write failure
86 Communications failure
BACKPLANE or OPTIONAL INTERFACE MODULE
A0 Unable to program the Option Card
A1 Unable to power the Option Card
A2 Unable to program the Backplane module
A3 Unable to program the Warp Module
Clear system errors with Exit Exit . If you encounter a system error, try resetting the projector by powering it off and on
again (wait at least 90 seconds and allow for proper cooling). For detailed information, monitor the RS232 IN port. Contact
dealer/factory if error persists and if a code appears that is not listed.
Sounds like you have a error 60 code.
You have to get software from Christie to reload it.
Should the glass plate rotate when using it just as an oven
Failed the emission test in Tx.I took the car in and they told me it didn't pass due to 02 sensor. We drove the car over 30 miles before taken it back for a second emission test at the same place since I had paid for it. The guy did the test again Engine off Fail Catalyst. He states the catalyst is not working and not reading the sensor. also states cheap gas could be causeing the fail.States to drive the car more with the different gas and it might work or I might need a new converter.Do I need to drive the car over 200 miles or fixed the converter?
When it runs idle it runs so rich that it burns your eyes.
how do you connect a wireless playstation 3 rock candy remote controller
