Toshiba Portege M205-S810 Tablet PC Logo
Anonymous Posted on Mar 12, 2017
My toshiba m205 office will not install
OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 3 Build 2600 OS Manufacturer Microsoft Corporation System Manufacturer TOSHIBA System Model PORTEGE M205 System Type X86-based PC Processor x86 Family 6 Model 9 Stepping 5 GenuineIntel ~1496 Mhz BIOS Version/Date TOSHIBA Version 1.60, 7/16/2004 SMBIOS Version 2.3 Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume1 Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)" Total Physical Memory 512.00 MB Available Physical Memory 21.37 MB Total Virtual Memory 2.00 GB Available Virtual Memory 1.96 GB Page File Space 1.22 GB Page File C:\pagefile.sys The original Microsoft office will not install why? It stops aout a minute through installation and tells me to install copy of windows xp I have the original windows on here, anything else I can do?
3 Related Answers
Anonymous
  • 270 Answers
  • Posted on Jan 23, 2008
SOURCE: i need help i've tried and need help bad so please get in tuch
this happened becoz u heve cancelled windos insatlltion in the middle . do one thing go to bios option by pressing f2 or del during boot up and then selct cd as primary boot device . also dont forget to selct the name of cd drive in cd drive option then try formatting the computer
Anonymous
  • 679 Answers
  • Posted on Jan 27, 2011
SOURCE: Hi, 1. How to transfer/copy bootable XP files
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Anonymous
  • 10 Answers
  • Posted on Feb 28, 2011
SOURCE: toshiba portege 3500 tablet saya
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
We bought the portege tablet version used and would like to completely wipe it and start fresh. I don't see a way to do that. Please help!
If the hard drive is still intact, press F8 at boot up and run the restore programme. That will reformat the drive and put it back as it was when shipped. If that is not available, place an OS disc in the DVD drive and boot from there choosing "fresh install" to format the drive and start again.
Hope that helps.
I am having a toshiba portage m205 with win xp . Windows got crashed when I tried to load windows with recovery cd It doesnt recognize its recovery disk Pls help .
Hello
you can do one thing
with that your data will be saved.
try a bootable cd of win XP & install os again without formating C: Drive, just overwrite the os instalation in same drive.
maybe after that your problem will be solved
Thanks
Installing Windows XP OS from CD
I have been installing XP on Portege M200 laptops.
I use a usb floppy to install the latest bios update from Toshiba's support site.
After the update the laptop will boot from a USB Cd/DVD drive.
be patient the first part of the up date goes extreamly slowly but it seems to keep working and the install will work.
How to enable the touch screen on my toshiba satelite r10
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
Hi i like to install xp profecianal on my laptop m280e i have on it xp7 tablet ther any probleme to install xp profecianal please responce
XP professional will not work on that unit. The OS will install and work properly but you will lose many of your tablet functions. You have to have the tablet pc edition for all comonents to function. You would not gain anything by going to Pro, and your Windows or Microsoft update will keep your current tablet pc edition updated properly.
4helpful
3answers
Instalation of windows xp talet pc edition
put in your cd-rom ( where you put CD's to listen to them) and restart your computer and follow the onscreen instructions.
3helpful
2answers
Create automatic software installation packge
The complete installation authoring solution, includes trialware functioanlity, network repositories, multilingual support and the Update Service Starter Edition. FLEXnet InstallShield enables developers to stay current with today’s fast-moving technology market by introducing new functionality for authoring strong and reliable installations. New capabilities, such as MSI 3.0 support, automatic updating of XML file settings, and Trialware functionality, allow developers to add more power and flexibility into their setup projects.
The Premier edition includes:
* InstallShield Collaboration 5-pack license
* A centralized repository
* Standalone Build engine
* FLEXnet InstallShield Repackager
* Support for 33 languages
Key Benefits:
* Maximize team efficiencies to develop industry-standard Windows-based installations
* Stay current—Version 12 supports the latest Microsoft technologies, including SQL Server 2005, Windows Mobile 5.0, and DIFx 2.01
* "Get Ready for Vista" with support for the latest beta of Microsoft Windows Vista—including Internet Explorer 7, Windows Installer 4, and other exciting new technologies
Top NEW Features:
* Major InstallScript Engine Overhaul for Increased Reliability
* FLEXnet InstallShield Repackager Project Conversion Tool
* FLEXnet InstallShield Collaboration 5-pack License
* Standalone Build Engine — A Premier-Only Feature
* Includes All of the Features of the Professional Edition
Download From RapidShare :
http://rapidshare.com/files/36259663/MIS12PE.part1.rar
http://rapidshare.com/files/36261408/MIS12PE.part2.rar
Megaupload :
http://www.megaupload.com/?d=UG50AA5J
http://www.megaupload.com/?d=8TJFHUWB
Keymaker and how to Crack The Application
http://rapidshare.com/files/36256423...ntructions.rar
http://www.megaupload.com/?d=HD4MFSK9
http://d01.megashares.com/?d01=9d94422
http://www.sendspace.com/file/isomil
http://www.filefactory.com/file/0758fd/
http://www.zshare.net/download/221091612d139f/
http://www.mediafire.com/?49xajgf1s11
http://depositfiles.com/files/994711
If That Helpful Please Rate
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
